path: root/configs/P1020RDB-PC_SPIFLASH_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-08configs: Resync with savedefconfigTom Rini
2020-05-04configs: P1020RDB: enable DM_I2C and DM_RTCBiwen Li
This enables DM_I2C and DM_RTC in P1020RDB defconfigs Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-23configs: p1020: enable CONFIG_DM_USB supportRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-25configs: enable eSDHC device module for P1020RDB boardYinbo Zhu
Enable eSDHC device module for P1020RDB board Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-28configs: P1020RDB: Enable PCIe driverHou Zhiqiang
Enable the DM PCIe driver in P1020RDB defconfig. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-26powerpc: Enable device tree support for P1020RDBHou Zhiqiang
Add device tree for P1020RDB boards and enable CONFIG_OF_CONTROL so that device tree can be compiled. Update board README for device tree usage. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: P1020RDB-PC: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1020RDB_PC instead of sharing with TARGET_P1_P2_RDB_PC to simplify Kconfig and config macros. Remove macro CONFIG_P1020RDB_PC. Signed-off-by: York Sun <york.sun@nxp.com>
