path: root/configs/P2020RDB-PC_NAND_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-08configs: Resync with savedefconfigTom Rini
2020-05-04configs: P2020RDB: enable DM_I2C and DM_RTCBiwen Li
This enables DM_I2C and DM_RTC in P2020RDB defconfigs Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-23configs: P2020: enable CONFIG_DM_USB supportRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when CMD_MTDPARTS is selectedMiquel Raynal
MTD support must be enabled when using mtdparts. Indeed, functions like get_mtd_info(), get_mtd_device() and put_mtd_device() are in drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-25configs: enable eSDHC device module for P2020RDB boardYinbo Zhu
Enable eSDHC device module for P2020RDB board Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-28configs: P2020RDB: Enable PCIe driverHou Zhiqiang
Enable the DM PCIe driver in P2020RDB defconfig. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-26powerpc: Enable device tree support for P2020RDBHou Zhiqiang
Add device tree for P1020RDB boards and enable CONFIG_OF_CONTROL so that device tree can be compiled. Update board README for device tree usage. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-08-13configs: mpc85xx: fix fallout from SPL/TPL changesPhilipp Tomsich
Splitting the feature selection for SPL and TPL, caused a few build failures to mpx85xx boards. This fixes the fallout by adding the needed new option names to the respective defconfig files. Signed-off-byL Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
