path: root/configs/T1042RDB_PI_defconfig
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-23configs: T104x: enable CONFIG_DM_USB supportRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: T1042RDB_PI: Split from T1042RDB in KconfigYork Sun
Use separated TARGET_T1042RDB_PI to simplify config options. Remove macro CONFIG_T1042RDB_PI. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1042: Remove macro CONFIG_PPC_T1042York Sun
Replace CONFIG_PPC_T1042 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T104XRDB: Split to T1040RDB and T1042RDB in KconfigYork Sun
Split ARCH_T104XRDB as ARCH_T1040RDB and ARCH_T1042RDB in Kconfig to simplify config options. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert CONFIG_CFB_CONSOLE_ANSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
