path: root/configs/T2080QDS_SECURE_BOOT_defconfig
2020-05-08configs: Resync with savedefconfigTom Rini
2020-05-04configs: T2080: enable DM_I2CBiwen Li
This enables DM_I2C in T2080 defconfigs Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-28configs: Resync with savedefconfigTom Rini
2020-02-25Revert "configs: enable sata device module in T2080QDS"Peng Ma
This reverts commit 02dc1599ba0b16eb21ba0c206e5b6f38fe7b67a7 Commit 02dc1599ba0b ("configs: enable sata, eSDHC, USB device module in T2080QDS") has some sata defconfig changes to fit support DM mode, Now the driver will be reverted, So revert it. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-08freescale/powerpc: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename the CONFIG_SECURE_BOOT name to CONFIG_NXP_ESBC to avoid conflicts with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-06-20configs: T2080QDS: Enable PCIe driverHou Zhiqiang
Enable the DM PCIe driver in T2080QDS defconfig. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-23configs: enable sata, eSDHC, USB device module in T2080QDSPeng Ma
Enable eSDHC, SATA and USB DM for T2080QDS in uboot Signed-off-by: Peng Ma <peng.ma@nxp.com> Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-23configs: T2080QDS: enable device tree support for pcieboot & secure bootYinbo Zhu
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02powerpc: mpc85xx: Move SECURE_BOOT to KconfigYork Sun
Move from CONFIG_SYS_EXTRA_OPTIONS to Kconfig option. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T2080, T2081: Remove macro CONFIG_PPC_T2080 and CONFIG_PPC_T2081York Sun
Use CONFIG_ARCH_T2080 and CONFIG_ARCH_T2081 instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T208XQDS: Split as T2080QDS and T2081QDSYork Sun
Use two separated targets in Kconfig to simplify configurations. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
