path: root/configs/UCP1020_defconfig
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-10configs: Resync with savedefconfigTom Rini
2017-12-26Move CONFIG_PANIC_HANG to KconfigMasahiro Yamada
Freescale (NXP) boards have lots of defconfig files per board. I used "imply PANIC_HANG" for them. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-11Convert CONFIG_CMD_MMC_SPI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_MMC_SPI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-04-30fs: Kconfig: Add a separate option for FS_CRAMFSSimon Glass
Rather than using CMD_CRAMFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CRAMFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CRAMFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CRAMFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-04powerpc/mpc85xx: Add board support for ucp1020Oleksandr G Zhadan
New QorIQ p1020 based board support from Arcturus Networks Inc. http://www.arcturusnetworks.com/products/ucp1020/ Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com> Signed-off-by: Oleksandr G Zhadan <oleks@arcturusnetworks.com> [York Sun: remove patman tags from commit message] Reviewed-by: York Sun <yorksun@freescale.com>
