path: root/configs/adp-ag101p_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2018-03-30configs: Drop CONFIG_MMC_NDS32Rick Chen
Remove CONFIG_MMC_NDS32 from the three config (adp-ae3xx_defconfig, adp-ag101p_defconfig, nx25-ae250_defconfig). Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Cc: Greentime Hu <green.hu@gmail.com>
2018-03-30mmc: ftsdc010: Migrate CONFIG_FTSDC010_SDIO to KconfigRick Chen
Convert CONFIG_FTSDC010_SDIO to Kconfig. So CONFIG_FTSDC010_SDIO can also be removed from config_whitelist.txt. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Cc: Greentime Hu <green.hu@gmail.com>
2018-02-14configs: Resync with savedefconfigTom Rini
2017-11-30nds32: board: Support ftsdc010 DM.Rick Chen
AG101P/AE3XX enable ftsdc010 dm flow. Signed-off-by: Rick Chen <rick@andestech.com>
2017-05-23nds32: eth: Support ftmac100 DM.rick
Support Andestech eth ftmac100 device tree flow on AG101P/AE3XX platform. Verification: Boot linux kernel via dhcp and bootm ok. NDS32 # setenv bootm_size 0x2000000;setenv fdt_high 0x1f00000; NDS32 # dhcp 0x600000 10.0.4.97:boomimage-310y-ae300-spi.bin BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4899 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'boomimage-310y-ae300-spi.bin'. Load address: 0x600000 Loading: ################################################################# ################################################################# ################################################################# ... ... ################################### 233.4 KiB/s done Bytes transferred = 13872076 (d3abcc hex) NDS32 # dhcp 0x2000000 10.0.4.97:ae300.dtb BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4592 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'ae300.dtb'. Load address: 0x2000000 Loading: # 82 KiB/s done Bytes transferred = 2378 (94a hex) NDS32 # bootm 0x600000 - 0x2000000 Image Name: Created: 2017-03-22 6:52:03 UTC Image Type: NDS32 Linux Kernel Image (uncompressed) Data Size: 13872012 Bytes = 13.2 MiB Load Address: 0000c000 Entry Point: 0000c000 Verifying Checksum ... OK Booting using the fdt blob at 0x2000000 Loading Kernel Image ... OK Loading Device Tree to 01efc000, end 01eff949 ... OK Linux version 3.10.102-20375-gb0034c1-dirty (rick@app09) (gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) ) #293 PREEMPT Wed Mar 22 14:49:28 CST 2017 CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d11103f(id 13, rev 17, cfg 4159) ... ... Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AE3XX platform.rick
Support Andestech AE3xx platform: serial, timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P timer DM.rick
Support AG101P timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P serial DM.rick
Support AG101P serial device tree flow. Signed-off-by: rick <rick@andestech.com>
