path: root/configs/alt_defconfig
2016-08-17arm: rmobile: Update defconfigNobuhiro Iwamatsu
This updated defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-04-18ARM: rmobile: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-25arm: rmobile: alt: Add support SDHINobuhiro Iwamatsu
Alt board has two SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Alt board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: kconfig: Remove '+S:' prefix from defconfig filesNobuhiro Iwamatsu
'+S' is unnecessary because boards of rmobile do not use SPL. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
