Set the ver environment variable consistently in all modules.
Move the define form include/configs into the defconfig were
applicable and create a new minimal defconfig.
Enable Serial Download Protocol (SDP) in SPL. This is useful to
make use of imx_usb to download the complete U-Boot (u-boot.img)
after SPL has been downloaded.
FIT image support is used by the upcoming Toradex Easy Installer
and also can be useful for more advanced boot scenarios.
Device tree overlays might prove useful in the future, enable it
by default on all our modules.
All modules use the common g_dnl_bind_fixup implementaton which
calculates the PID according to product id (read from the config
block) plus offset of 0x4000. In case there is no config block
support (e.g. SPL) or in case the config block is not readable,
fall back to a generic product id (product id 0, which can be
interpreted as "Unknown Module").
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
commercial and industrial temperature range.
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
