path: root/configs/aristainetos2c_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-03-09imx6, aristainetos2c: add da9063 pmic setupHeiko Schocher
On the aristainetos2c boards the PMIC needs to be initialized, because the Ethernet PHY uses a different regulator that is not setup per hardware default. This does not influence the other versions as this regulator isn't used there at all. Signed-off-by: Heiko Schocher <hs@denx.de>
2020-02-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-07imx6: aristainetos: add support for rev C boardHeiko Schocher
add support for revision C boards. This board has no longer a NAND. Signed-off-by: Heiko Schocher <hs@denx.de>
