path: root/configs/at91sam9g20ek_2mmc_nandflash_defconfig
2020-06-04configs: Resync with savedefconfigTom Rini
2020-02-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-04board: at91sam9260ek: Use SPI-flash-based AT45xxx DataFlashWenyou.Yang@microchip.com
To support driver model and device tree, use the SPI-flash-based AT45xxx DataFlash driver, DataFlash is a kind of SPI flash. Instead of ATMEL_DATAFLASH_SPI DataFlash older driver that will be removed in the future. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09board: at91sam9260ek/9g20ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9260ek/9g20ek: Update for DT and DMWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
