path: root/configs/at91sam9m10g45ek_mmc_defconfig
2020-06-04configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09board: at91sam9m10g45ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9m10g45ek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
