The symbol "CONFIG_ARM_DCC" is used to control building
drivers/serial/arm_dcc.c. Provide a simple Kconfig entry for this.
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Tom McLeod <tom.mcleod@opalkelly.com>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
Convert another option Kconfig.
Reported-by: Robert P. J. Day <rpjday@crashcourse.ca>
In past SPL_ZYNQMP_TWO_SDHCI symbol was introduced to handle boards with
two sdhci controllers. The problem was that U-Boot is registering
controllers based on aliases in DT but bootmode targets specific controller
ID. That's why on boards with one "second" sdhci controller bootmode was
pointing to second controller(MMC2) but alias was setup to mmc0 (the first
controller). And SPL requires to point to mmc0 in this case.
Long time ago commit f101e4bd3703
("spl: add support for alternative boot device") added support for handling
multiple bootmodes in SPL. Use this functionality and setup second sdhci
controller as backup boot device.
Below is table with behavior:
HW/bootmode bootorder
sd0/sd0 mmc0/mmc1 (mmc1 never called)
sd1/sd1 mmc1/mmc0 (mmc0 fails and mmc1 is called)
sd0+sd1/sd0 mmc0/mmc1 (mmc1 never called)
sd0+sd1/sd1 mmc1/mmc0 (mmc0 never called)
All other bootmodes are not affected but order can be extended to cover
advance boot flows.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
All boards are using the same prompt that's why add it as default value to
Kconfig to simplify defconfigs.
Define default address via Kconfig. There is no need to change this address
for most of the boards but it is also possible. This one line save a lot of
lines in defconfigs that's why make sense to do it.
The similar change has been done by commit 9340d8fe8beb
("sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to Kconfig")
Avnet UltraZed-EV Starter Kit is composed by the UltraZed-EV SoM and the
only publicly-available compatible carrier card. The SoM is based on the EV
version of the Xilinx ZynqMP SoC+FPGA.
The psu_init_gpl.c file has been generated from the board definition files
at [0] using Vivado 2018.3 and then minimized by
tools/zynqmp_psu_init_minimize.sh. Manually removed serdes init code since
it is not mentioned in device tree and fixed a checkpatch error.
[0] https://github.com/Avnet/bdf/tree/3686c9ff7d2f0467fb4fcf39f861b8d6ff183b12/ultrazed_7ev_cc/1.1
Signed-off-by: Luca Ceresoli <luca@lucaceresoli.net>
