path: root/configs/bcm11130_nand_defconfig
2020-02-09cmd: mdc/mwc: normalize disjoint MX_CYCLIC usageJoel Johnson
Both CMD_MX_CYCLIC and MX_CYCLIC are in use and defined in Kconfig, but only the non-CMD version currently does anything. This changes all usages to prefer the CMD_MX_CYCLIC option (since it's only affecting addition of the commands), and switches defconfigs using the non-CMD version to use the CMD version. Signed-off-by: Joel Johnson <mrjoel@lixil.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-04configs: remove MTD support from bcm11130 and M54418TWR defconfigsMiquel Raynal
While the right Kconfig entries were selected, because of the missing CMD_NAND symbol the raw NAND core was never compiled. Remove it from the defconfigs otherwise the build will fail. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Also do this on bcm11130_nand] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-08-23Convert CONFIG_MX_CYCLIC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MX_CYCLIC Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: David Lechner <david@lechnology.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-13arm: bcm281xx: choose 8-bit phy bus widthSteve Rae
The Kona PHY supports an 8-bit wide UTMI interface, therefore, choose this Kconfig setting. Signed-off-by: Steve Rae <srae@broadcom.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-11-23ARM: bcm: Enable bcm11130 boardsSteve Rae
bcm11130 bcm11130_nand Signed-off-by: Steve Rae <srae@broadcom.com>
