path: root/configs/bf537-pnav_defconfig
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
