path: root/configs/bubblegum_96_defconfig
2020-04-24actions: Move defconfig options to KconfigAmit Singh Tomar
This patch moves some of the config options from bubblegum_96_defconfig to respective Kconfig files. Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-24clk: actions: Add common clock driverAmit Singh Tomar
This patch converts S900 clock driver to something common that can be used for other SoCs, for instance S700(few of clk registers are same). Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-04-24arm: actions: Add common framework for Actions Owl Semi SoCsAmit Singh Tomar
This commit adds common arch support for Actions Semi Owl series SoCs and removes the Bubblegum96 board files. Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-01-07configs: Resync with savedefconfigTom Rini
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-09board: Add uCRobotics Bubblegum-96 board supportManivannan Sadhasivam
This commit adds uCRobotics Bubblegum-96 board support. This board is one of the 96Boards Consumer Edition platform based on Actions Semi S900 SoC. Features: - Actions Semi S900 SoC (4xCortex A53, Power VR G6230 GPU) - 2GiB RAM - 8GiB eMMC, uSD slot - WiFi, Bluetooth and GPS module - 2x Host, 1x Device USB port - HDMI - 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons U-Boot will be loaded by ATF at EL2 execution level. Relevant driver support will be added in further commits. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
