Veyrons do not need full pinctrl support for SPL.
The full pinctrl support does nothing when enabled with OF_PLATDATA,
thus was already unused.
This frees about 4kB of SPL size.
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Previously veyron_init() was called in board_init() context, which is
called after relocation. Moving it to veyron.c used board_early_init_f
which is called way earlier, and causes veyron_init to hang.
Using board_early_init_r instead fixes this.
Fixes: b678f2790c ("rockchip: rk3288: Move veyron_init() back to veyron.c")
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
Updates jerry, mickey, minnie and speedy defconfigs to:
- fit the SPL in 32k
- boot from SPI (only)
- remove gadget support (these have no OTG port)
(Rebase on top of tree)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Affects rk3288 veyrons and rk3036, this was mostly done by
moveconfig.py.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
There is no difference in rk3288 board use for SYS_MALLOC_F_LEN,
so we can use default value.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Completely move CONFIG_SPI_FLASH from remaining board header files to
defconfigs
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
If we used the pinctrl-rockchip driver, these config is not needed,
so remove them.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The FDT is requested for new pinctrl driver, disable SPL_OF_PLATDATA
and enable SPL_OF_LIBFDT to make FDT be built in.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Currently the fdtfile environment variable is set to
CONFIG_DEFAULT_DEVICE_TREE which is іnternally used as U-Boot devicetree
source. The OS can use a different filename and Kconfig gives us the
ability to select a default devicetree via CONFIG_DEFAULT_FDT_FILE.
This also gives user configuring U-Boot via menuconfig the behaviour
someone would expect.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Tested-By: Vagrant Cascadian <vagrant@debian.org>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Convert USB fastboot code to use shared fastboot protocol.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
We have enable NS16550 in Kconfig, do not need enable at defconfig
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
After moving some USB gadget configs (USB_FUNCTIONS_*) to Kconfig it
turned out that following *_defconfig entries for RockChip are not
needed.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
CONFIG_ROCKCHIP_USB2_PHY
this patch enable rockusb support on rk3288 based device.
Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
CONFIG_CMD_SF_TEST
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
