CONFIG_BZIP2
CONFIG_GZIP
CONFIG_LZO
CONFIG_ZLIB
CONFIG_LZMA
CONFIG_LZO
If these phases are used we typically want to enable pinctrl in then, so
that pad setup and GPIO access are possible.
The existing work-around for positioning U-Boot in the ROM when it
actually runs from RAM still exists and there is not obvious way to change
this.
Add a proper Kconfig option to handle this case. This also adds a new bool
property to indicate whether CONFIG_SYS_TEXT_BASE exists.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SHOW_BOOT_PROGRESS
Improvements and new features:
- split more rockchip pinctrl_core feature into per SoC
- enable TPL for evb-rk3399 board
- enable TPL/SPL for evb-px5 board
- enable TPL and OP-TEE support for evb-rk3229
- update fix in arm common assembly start code for rockchip header file
- update default SPL_FIT_GENERATOR for rockchip
- rk3399 boards update to use '-u-boot.dtsi'
- add new rk3399 boards: Nanopi M4, Nanopc T4
- enable sound for chromebook_minnie
Add a version of samus which supports booting from TPL to SPL and then
to U-Boot. This allows TPL to select from an A or B SPL to support
verified boot with field upgrade.
