Veyrons do not need full pinctrl support for SPL.
The full pinctrl support does nothing when enabled with OF_PLATDATA,
thus was already unused.
This frees about 4kB of SPL size.
Signed-off-by: Urja Rannikko <urjaman@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Previously veyron_init() was called in board_init() context, which is
called after relocation. Moving it to veyron.c used board_early_init_f
which is called way earlier, and causes veyron_init to hang.
Using board_early_init_r instead fixes this.
Fixes: b678f2790c ("rockchip: rk3288: Move veyron_init() back to veyron.c")
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
Updates jerry, mickey, minnie and speedy defconfigs to:
- fit the SPL in 32k
- boot from SPI (only)
- remove gadget support (these have no OTG port)
(Rebase on top of tree)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Affects rk3288 veyrons and rk3036, this was mostly done by
moveconfig.py.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
There is no difference in rk3288 board use for SYS_MALLOC_F_LEN,
so we can use default value.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
This adds support for the ASUS C201, a RK3288-based clamshell
device. The device tree comes from linus's linux tree at
3f16503b7d2274ac8cbab11163047ac0b4c66cfe. The SDRAM parameters
are for 4GB Samsung LPDDR3, decoded from coreboot's
src/mainboard/google/veyron/sdram_inf/sdram-lpddr3-samsung-4GB.inc
Signed-off-by: Marty E. Plummer <hanetzer@startmail.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
