path: root/configs/controlcenterdc_defconfig
2020-06-04Convert CONFIG_BOARD_LATE_INIT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_LATE_INIT Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-22arm: mvebu: correct SPL boot configs for SPI/MMCJoel Johnson
Update mvebu SPL boot selection mechanism for the move to driver model usage by ensuring that the required driver support for SPI and MMC booting is available in SPL when the respective boot method is selected. Previously, all mvebu boards selected a boot method (implicitly MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used. This changes mvebu boot method selection to depend on SPL usage which resolves the issue with aarch64 boards which don't use SPL getting an implicit boot device selection resulting in unmet dependencies. The 32-bit arm boards do use SPL, but I'm led to conclude that most aren't intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have SPL_DM_SPI enabled in their defconfig even though they still implicitly select the SPI boot method. This also results in the new addition of SPL_GPIO_SUPPORT to helios4. The mainline dts for helios4 includes the cd-gpios entry for sdhci with identical addresses as the clearfog dts. I don't have a helios4 board to confirm, but based on the current source conclude that the board itself is either wired to pull the signal low for eMMC, or the default MMC boot isn't fully functional in mainline. In either case, as far as I can tell, including the GPIO support will at least cause no regression. Tested on SolidRun ClearFog devices. Signed-off-by: Joel Johnson <mrjoel@lixil.net> Reviewed-by: Stefan Roese <sr@denx.de>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-05-27arm: mvebu: controlcenterdc: Update configMario Six
Several drivers used by the ControlCenterDC board were converted to DM upstream. But the board had not been using these drivers yet. Update the board's config file to reflect these changes and use the DM version of these drivers. No further device tree updates are necessary, since the devices in question are already present in the device tree. This especially fixes the three compile warnings about CONFIG_DM_MMC, CONFIG_DM_USB, and CONFIG_AHCI for the ControlCenterDC board. Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-25controlcenterdc: move some configuration in defconfig filePatrick Delaunay
Move some configurations in defconfig file - CONFIG_CMD_I2C - CONFIG_CMD_SPI This allow correct dependency handling in Kconfig. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-02-05pci: pci_mvebu: Add DM_PCI support and move CONFIG_PCI_MVEBU to defconfigStefan Roese
This patch adds DM_PCI support to the MVEBU PCIe driver. This is necessary, since all PCI drivers have to be moved to DM (driver model) until the v2019.07 release. To not break git bisect'ablility, this patch also moves CONFIG_PCI_MVEBU from config headers to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2018-04-28Cleanup CONFIG_SPL_SERIAL_SUPPORT migrationAlex Kiernan
CONFIG_SPL_SERIAL_SUPPORT had already been migrated to Kconfig, but existed in some include files; fix those up here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-26ARM: mvebu: Convert CONFIG_MVNETA to KconfigChris Packham
This converts the following to Kconfig: CONFIG_MVNETA Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-08-11Convert CONFIG_CMD_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SCSI Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to enable the command, fixing an earlier error. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [trini: Rework to default y if SCSI, drop cl-som-am57x which did not use CMD_SCSI for real] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-31configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-23arm: mvebu: Add gdsys ControlCenter-Compact boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Marvell Armada 38x SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2 x GbE - Xilinx Kintex-7 FPGA connected via PCIe - mSATA - USB3 host - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
