path: root/configs/eb_cpu5282_defconfig
2020-01-10configs: add eth dm support for all ColdFire boardsAngelo Durgehello
Add dm eth config options for all involved ColdFire-based boards. Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24configs: enable use of DT for all m68k boardsAngelo Dureghello
Enable DT usage for all m68k boards. To provide a working single binary, the dts has been kept as embedded. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
