path: root/configs/edminiv2_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-15arm: orion5x: finish moving SoC to mach-orion5xTrevor Woerner
The SPL linker script had been left in arch/$(ARCH)/cpu/$(CPU)/$(SOC); therefore move it to the already-established arch/$(ARCH)/mach-$(SOC) location. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-05-15rename symbol: CONFIG_ORION5X -> CONFIG_ARCH_ORION5XTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch removes a TODO from the code. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-03-16edminiv2: Move CONFIG_SPL_LDSCRIPT to defconfigTom Rini
As there is only one machine under mach-orion5x, having a Kconfig entry for SPL_LDSCRIPT is not helpful, move this to the defconfig file. Suggested-by: Masahiro Yamada <masahiroy@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2018-05-16ARM: re-enable MVGBE for edminiv2Chris Packham
This was unintentionally disabled when moving MVGBE to Kconfig. Fixes: commit ed52ea507f12 ("net: add Kconfig for MVGBE") Signed-off-by: Chris Packham <judge.packham@gmail.com>
2017-12-12ata: Migrate CONFIG_MVSATA_IDE to KconfigTuomas Tynkkynen
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2015-02-25edminiv2: switch to SPLAlbert ARIBAUD
ED Mini V2 is based on Orion 5x which boots at fixed address 0xFFFF0000 in NOR Flash. Place SPL there, and switch U-Boot from .bin to .img format, stored in NOR Flash at 0xFFF90000. Note: this patch was tested on HW and works, i.e. it boots U-Boot properly, but SPL console output currently does not appear, due to GD being trashed by arch/arm/lib/spl.c. This trashing is soon to be removed, and then ED Mini V2 SPL console output will become visible. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-30orion5x: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Orion5x board select menu to orion5x/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="orion5x"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
