CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
enable basic DM/DTS support for the siemens am335x based boards.
add missing USB_MUSB_* and CONFIG_G_DNL_*
board configuration.
In the draco CPU board family, etamin is a new variant
with bigger flash and more RAM. Due to new flash that
uses larger pages (4K) some changes are necessary because
it impacts the MTD partition layout and the ubi mount
parameters.
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
[trini: Move BOOTDELAY into defconfig, just always be 3 now]
