path: root/configs/evb-px30_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-04Merge tag 'u-boot-rockchip-20200501' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - dts clean up to use -u-boot for px30, rk3399 boards - dts sycn from upstream kernel for rk3328, rk3399 - add rockchip rng driver - new board support: rk3328-roc-cc, rk3399-roc-pc,Nanopi M4 2GB
2020-04-29rockchip: px30: Enable CONFIG_RNG_ROCKCHIPLin Jinhan
CONFIG_RNG_ROCKCHIP/CONFIG_DM_RNG is enabled. Signed-off-by: Lin Jinhan <troy.lin@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-01-30rockchip: px30: remove CONFIG_OPTEE supportKever Yang
Rockchip use CONFIG_SPL_OPTEE for OPTEE support, which is load and run before U-Boot, but not use CONFIG_OPTEE which is after U-Boot. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-21configs: Resync with savedefconfigTom Rini
2019-11-17rockchip: add px30-evb boardHeiko Stuebner
The px30 evb is an evaluation board for the px30 together with a dsi- connected display. This adds board and config files for it. Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
