path: root/configs/fennec-rk3288_defconfig
2019-02-07configs: Move CONFIG_SPI_FLASH into defconfigsVignesh R
Completely move CONFIG_SPI_FLASH from remaining board header files to defconfigs Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-01rockchip: defconfig: Clean the unused pinctrl configDavid Wu
If we used the pinctrl-rockchip driver, these config is not needed, so remove them. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-07-21rockchip: utilize CONFIG_DEFAULT_FDT_FILEKlaus Goger
Currently the fdtfile environment variable is set to CONFIG_DEFAULT_DEVICE_TREE which is іnternally used as U-Boot devicetree source. The OS can use a different filename and Kconfig gives us the ability to select a default devicetree via CONFIG_DEFAULT_FDT_FILE. This also gives user configuring U-Boot via menuconfig the behaviour someone would expect. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Tested-By: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-25rockchip: defconfig: remove CONFIG_SYS_NS16550Kever Yang
We have enable NS16550 in Kconfig, do not need enable at defconfig Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-02Kconfig: usb: rockchip: Remove not needed *_defconfig USB/gadget entriesLukasz Majewski
After moving some USB gadget configs (USB_FUNCTIONS_*) to Kconfig it turned out that following *_defconfig entries for RockChip are not needed. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_MASS_STORAGE to KconfigLukasz Majewski
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-01-22Convert CONFIG_ROCKCHIP_USB2_PHY to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ROCKCHIP_USB2_PHY Signed-off-by: Adam Ford <aford173@gmail.com>
2018-01-10rockchip: rk3288: enable rockusb support on rk3288 based deviceEddie Cai
this patch enable rockusb support on rk3288 based device. Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPLPhilipp Tomsich
The back-to-bootrom option is rather unfortunately named CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM instead of CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM), we need to rename it. At the same time, we introduce a TPL_ variant of the option to give us finer-grained control over when it should be used. This change is motivated by our RK3368 boot process, which returns to the boot ROM only from the TPL stage, but not from the SPL stage. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:] [fixed inverted CONFIG_IS_ENABLED test for rk3288:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> include/configs/rock.h: undef
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: config: enable the USB host for rk3288 based boardEddie Cai
RK3288 using the dwc2 USB host controller, enable it and other usb host funtion like storage and ethernet. Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-16rockchip: configs: Enable networking support on rk3288 boardsJacob Chen
At current, only firefly and rock2 have network enabled. Let's enable other boards. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-11mmc: rename CONFIG_ROCKCHIP_DWMMC to CONFIG_MMC_DW_ROCKCHIPMasahiro Yamada
I am trying to make all DesignWare-based driver options prefixed with CONFIG_MMC_DW_. This commit was generated as follows: find . -name .git -prune -o -type f -print | \ xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g' Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-30rk3288: config change for enable dram capacity auto-detect.Kever Yang
Enable ROCKCHIP_SPL_BACK_TO_BROM and disable CONFIG_SPL_MMC_SUPPORT to save memory in order to enable add source code for dram capacity auto-detect. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
