path: root/configs/ficus-rk3399_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-30rockchip: rk3399: Enable DISPLAY_CPUINFOJagan Teki
RK3288, RK3399 are now support cpu-info, so enable DISPLAY_CPUINFO by default. Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-11-11Merge tag 'u-boot-rockchip-20191110' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Add support for rockchip pmic rk805,rk809, rk816, rk817 - Add rk3399 board Leez support - Fix bug in rk3328 ram driver - Adapt SPL to support ATF bl31 with entry at 0x40000 - Fix the u8 type comparision with '-1'. - Fix checkpatch warning for multi blank line and review signature.
2019-11-10rockchip: rk3399: update SPL_STACK_R_ADDRKever Yang
Use the same SPL_STACK_R_ADDR in Kconfig instead of each board config; default to 0x4000000(64MB) instead of 0x80000(512KB) for this address can support all the SoCs including those may have only 64MB memory, and also reserve enough space for atf, kernel(in falcon mode) loading. After the ATF entry move to 0x40000, the stack from 0x80000 may be override when loading ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-23rockchip: rk3399: defconfig: remove SPL raw image supportKever Yang
RK3399 SPL only support FIT image for ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-20rockchip: rk3399: default enable SPL LIBCOMMON and LIBGENERICKever Yang
We needs SPL LIBCOMMON and LIBGENERIC for all boards, so we can enable them by default and no need to define in each board. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-20rockchip: rk3399: use default value for SYS_MALLOC_F_LENKever Yang
There is no difference in rk3399 board use for SYS_MALLOC_F_LEN, so we can use default value. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08arm: rockchip: rk3399: Move common configs in KconfigJagan Teki
Few SPL and U-Boot proper configs are common to all rk3399 target defconfigs, move them and select it from platform kconfig. Moved configs: - SPL_ATF - SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF - SPL_LOAD_FIT - SPL_CLK if SPL - SPL_PINCTRL if SPL - SPL_RAM if SPL - SPL_REGMAP if SPL - SPL_SYSCON if SPL - CLK - FIT - PINCTRL - RAM - REGMAP - SYSCON - DM_PMIC - DM_REGULATOR_FIXED Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08Kconfig: Add default SPL_FIT_GENERATOR for rockchipJagan Teki
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT. So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator. Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-06rockchip: rk3399: Add Ficus EE board supportManivannan Sadhasivam
Add board support for Ficus EE board from Vamrs. This board utilizes common Rock960 family support. Following peripherals are tested and known to work: * Gigabit Ethernet * USB 2.0 * MMC Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> [Reworked based on common Rock960 family support] Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
