path: root/configs/guruplug_defconfig
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
