path: root/configs/k2g_evm_defconfig
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-08-16defconfig: k2g_evm_defconfig: Enable mmc driver modelSekhar Nori
K2G can benefit from driver model support in the MMC/SD driver it uses: omap_hsmmc Enable driver model MMC support for K2G. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-09defconfig: k2g_evm_defconfig: Enable Cadence QSPI controllerVignesh R
Enable Cadence QSPI controller support to use QSPI on K2G SoC. Also enable Spansion flash support to access s25fl512s flash present on K2G QSPI bus. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-09defconfig: k2g_evm_defconfig: enable SPI driver modelVignesh R
Enable SPI and SPI Flash driver model as K2G SPI controller driver supports driver model. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-06-04usb: move CONFIG_USB_XHCI_DWC3 to KconfigMasahiro Yamada
Create an entry for "config USB_XHCI_DWC3" in Kconfig and switch over to it for all boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-03-14configs: k2g_evm: Add TI power processor supportNishanth Menon
Enable support for PMMC the TI power processor on K2G. This processor manages all power management related activities on the SoC and and allows the Operating Systems on compute processors such as ARM, DSP to offload the power logic away into the power processor. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08defconfig: k2g_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2g evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-22ARM: k2g: Add config fileLokesh Vutla
Add config file for k2g Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
