path: root/configs/khadas-vim2_defconfig
2020-06-04configs: Resync with savedefconfigTom Rini
2020-04-28configs: khadas-vim2: enable support for SPI NOR flashNeil Armstrong
Add the necessary configs to use the SPI NOR flash. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-04-20configs: khadas-vim2: Enable USB gadget with Mass Storage functionNeil Armstrong
Enable configs to support USB gadget and Mass Storage Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-23board: amlogic: enable PHY_REALTEK for selected boardsNeil Armstrong
When using the generic PHY on boards using an RGMII Realtek PHY, gigabit speed is not always reliable. This patch enables the Realtek PHY driver for such boards. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10ARM: meson: display Amlogic SoC InformationJulien Masson
The Amlogic SoCs have a registers containing the die revision and packaging type to determine the SoC family and package marketing name like S905X for the GXL SoC Family. This code is taken from the Linux meson-gx-socinfo driver and adapted to U-Boot printing. Signed-off-by: Julien Masson <jmasson@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [narmstrong: also updated new p200/p201 defconfigs]
2019-04-03configs: khadas_vim2: Fix defconfigNeil Armstrong
The Khadas VIM2 defconfig was missing the USB PHY config and two other misc configs to setup dram banks and call misc_init_r. Align it on the other Amlogic SoC based boards defconfig. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-31arm: meson64: enable console mux and console env by defaultMaxime Jourdan
With the recent addition of the meson VPU driver, enable the following config entries by default for meson-64 targets: CONFIG_CONSOLE_MUX, CONFIG_SYS_CONSOLE_IS_IN_ENV. This allows outputting the console via video if CONFIG_VIDEO_MESON is selected. Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-26ARM: rework amlogic configurationJerome Brunet
Rework the board SYS_BOARD, SYS_VENDOR and SYS_CONFIG_NAME setup by moving the board Kconfig into the mach-meson Kconfig to make it easier to add new boards for a SoC architecture and add a custom config header or custom board handler for a platform. This drops the board CONFIGs and the duplicate boards configs headers in favor of a single meson64.h config header. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: move khadas-vim2 as q200 ref boardNeil Armstrong
The Khadas vim2 derive from amlogic s912 reference design (Q200). This patch moves the khadas-vim2 board support to a generic Q200 board, while keeping a dedicated defconfig to customize the names and device tree. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-10ARM: meson: Add Khadas VIM2 board supportLoic Devulder
This adds platform code for the Khadas VIM2 board based on a Meson GXM (S912) SoC with the Meson GXM configuration. This initial submission supports UART, MMC/SDCard and Ethernet. USB is partially supported. All the code is from Neil Armstrong! I just rebased the code, do some cleanup and tested on my board. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
