path: root/configs/kmsupx5_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate arbiter config to KconfigMario Six
Migrate the arbiter configuration to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20keymile: Make distinct kmsupx5, tuge1, kmopti2, and kmtepr2 configsMario Six
The kmsupx5, tuge1, kmopti2, and kmtepr2 boards all build from the same include config file with lots of #ifdef logic. To ease Kconfig migration, create new config include files for these boards, and resolve the #ifdef logic as needed. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-17Migrate bootlimit to KconfigAlex Kiernan
Migrate boards which set bootlimit in the environment to Kconfig. We exclude gurnard_defconfig which includes a bootlimit=, but doesn't set CONFIG_BOOTCOUNT_LIMIT, so we'd fail to include a bootlimit setting if we migrated it. display5_defconfig and display5_factory_defconfig share a SYS_CONFIG_NAME, but only display5_defconfig enables CONFIG_BOOTCOUNT_LIMIT, so we fail to set bootlimit= in display5_factory_defconfig. This is okay because the display5_factory_defconfig doesn't need to have it set, as it is only meant to prepare the board in the factory. Environment changes for all modified configs as seen from buildman: boards.cfg is up to date. Nothing to do. Summary of 3 commits for 32 boards (8 threads, 1 job per thread) 01: Merge git://git.denx.de/u-boot-x86 arm: + draco etamin rastaban pxm2 display5 thuban rut 02: Add BOOTCOUNT_BOOTLIMIT to set reboot limit 03: Migrate bootlimit to Kconfig - display5_factory: bootlimit=3 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08treewide: Migrate CONFIG_LAST_STAGE_INIT to KconfigMario Six
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IMMAP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IMMAP Also move this command out of the cmd/ directory since it is PowerPC-specific. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
