path: root/configs/libretech_all_h3_cc_h3_defconfig
2020-03-18sunxi: Remove no longer needed default options from defconfigsAndre Przywara
Now that those common Allwinner config symbols are defined automatically for all boards in their Kconfig files, we can remove the now redundant definitions from the boards' _defconfig files. Some boards had a differing definiton for some of those symbols, it looks like mostly to "merge races" when the symbol was introduced (new board *_defconfig file missed the "add symbol to all files" patch). Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <mripard@kernel.org> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-15sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to KconfigAndre Przywara
The choice of the SPL_TEXT_BASE is not really a decision that should be specified by each board's defconfig, as this setting is actually dictated by the SoC's memory map and the BootROM behaviour. To make this obvious and reduce the clutter in the defconfig files, let's specify the SoC constraints in the Kconfig stanza. This allows us to remove these lines from the defconfig files again. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-04-10arm: sunxi: Enable DRAM ODT by default on H3/H5Paul Kocialkowski
Most of the boards we support with H3/H5 enable DRAM on-die termination, which is consistent with the high DRAM clocks that are used. Make it the default (like it's done for other similar platforms) instead of defining it in each defconfig. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-04-10arm: sunxi: Set the default DRAM ZQ value to 3881979 on H3/H5Paul Kocialkowski
Most H3/H5 boards we support have the DRAM ZQ value set to 3881979, which is also consistent with the default set for the R40. Make this value the default on H3/H5 instead of 123. Signed-off-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-18sunxi: usb: Switch to Generic host controllersJagan Teki
Onc of key blocker for using USB Generic host controller drivers in Allwinner are CLK and RESET drivers, now these available for USB usage. So switch sunxi USB use EHCI and OHCI Generic controllers. Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD where it already have USB_EHCI_HCD Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-07-17sunxi: Enable eMMC on Libre Computer Board ALL-H3-CC boardsChen-Yu Tsai
The Libretech ALL-H3-CC has a high density connector for attaching an eMMC module. The module form factor and connection is specific to Libretech, and has provisions for split vmmc/vqmmc (core and I/O) voltage supplies, but this board does not wire the vqmmc side. The H2+/H3/H5 SoCs do not support alternate I/O voltages for eMMC either. Only 3.3V is supported. A specific module that ties vqmmc to vmmc, with both at 3.3V, must be used. Given that a) eMMC is not designed to be hotplugged, b) power is always provided on the pins, and c) MMC controllers can deal with missing cards, we can enable this by default. If a module is attached it will be picked up by the system. The device tree change was also submitted to the Linux Kernel and has already been queued up for 4.19. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-05-01sunxi: Disable R_I2C for Libre Computer Board ALL-H3-CC H3 ver.Chen-Yu Tsai
The Libre Computer Board ALL-H3-CC does not have an I2C controllable regulator. Having R_I2C and SPL_I2C enabled serves no purpose. Disable them. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-10sunxi: Add support for Libre Computer Board ALL-H3-CC H3 ver.Chen-Yu Tsai
The Libre Computer Board ALL-H3-CC from Libre Technology is a Raspberry Pi B+ form factor single board computer based on the Allwinner H3 SoC. The board has 1GB DDR3 SDRAM, provided by 4 2Gb chips. The mounting holes and connectors are in the exact same position as on the Raspberry Pi B+. Raspberry Pi B+ like peripherals supported on this board include: - Power input through micro-USB connector (without USB OTG) - Native 100 Mbps ethernet using the internal PHY, as opposed to USB-based on the RPi - 4x USB 2.0 host ports, directly connected to the SoC, as opposed to being connected through a USB 2.0 hub on the RPi - TV and audio output on a 3.5mm TRRS jack - HDMI output - Micro-SD card slot - Standard RPi B+ GPIO header, with the standard peripherals routed to the same pins. * 5V, 3.3V power, and ground * I2C0 on the H3 is routed to I2C1 pins on the RPi header * I2C1 on the H3 is routed to I2C0 pins on the RPi header * UART1 on the H3 is routed to UART0 pins on the RPi header * SPI0 on the H3 is routed to SPI0 pins on the RPi header, with GPIO pin PA17 replacing the missing Chip Select 1 * I2S1 on the H3 is routed to PCM pins on the RPi header - Additional peripherals from the H3 are available on different pins. These include I2S0, JTAG, PWM1, SPDIF, SPI1, and UART3 In addition, there are a number of new features: - Console UART header - Consumer IR receiver - Camera interface (not compatible with RPi) - Onboard microphone - eMMC expansion module port - Heatsink mounting holes This patch adds defconfig and dts files for this board. The dts file is the same as the one submitted for inclusion in Linux, with some minor revisions to match the dtsi file and old EMAC bindings in U-boot. Since the OTG controller is wired to a USB host port, and the H3 has proper USB hosts to handle host mode, the MUSB driver is not enabled. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
