path: root/configs/ls1012afrwy_tfa_defconfig
2020-06-04Convert CONFIG_CMD_ASKENV et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CMD_ASKENV CONFIG_CMD_BMP CONFIG_CMD_BOOTD CONFIG_CMD_CACHE CONFIG_CMD_CRC32 CONFIG_CMD_DHCP CONFIG_CMD_ENV CONFIG_CMD_EXPORTENV CONFIG_CMD_EXT2 CONFIG_CMD_EXT4 CONFIG_CMD_FLASH CONFIG_CMD_FS_GENERIC CONFIG_CMD_FUSE CONFIG_CMD_GPIO CONFIG_CMD_GPT CONFIG_CMD_GREPENV CONFIG_CMD_I2C CONFIG_CMD_IMLS CONFIG_CMD_IMPORTENV CONFIG_CMD_LOADB CONFIG_CMD_LOADS CONFIG_CMD_MEMINFO CONFIG_CMD_MII CONFIG_CMD_MTDPARTS CONFIG_CMD_NAND CONFIG_CMD_NAND_TRIMFFS CONFIG_CMD_NFS CONFIG_CMD_PCA953X CONFIG_CMD_PCA953X_INFO CONFIG_CMD_PCI CONFIG_CMD_PING CONFIG_CMD_READ CONFIG_CMD_SF CONFIG_CMD_SPI CONFIG_CMD_SPL CONFIG_CMD_SPL_WRITE_SIZE CONFIG_CMD_TIME CONFIG_CMD_TRACE CONFIG_CMD_UBI CONFIG_CMD_UBIFS CONFIG_CMD_UNZIP CONFIG_FS_EXT4 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-19configs: ls1012a: Unset ENV_ADDR valueKuldeep Singh
LS1012A-FRWY and LS1012A-RDB crashes in flash environment when CONFIG_ENV_ADDR value is set. Unset the config value in *_tfa_defconfig* to resolve booting crash. Following crash is observed: Using SERDES1 Protocol: 13576 (0x3508) "Synchronous Abort" handler, esr 0x96000006 elr: 00000000820452c0 lr : 0000000082013f54 (reloc) elr: 00000000b7b932c0 lr : 00000000b7b61f54 x0 : 0000000000000000 x1 : 000000007604e004 x2 : 0000000000000001 x3 : 0000000000000000 ... Code: 54ffff80 9100c000 17fffff7 f9402241 (3860c820) Resetting CPU ... Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-19configs: nxp: Enable CONFIG_SYS_RELOC_GD_ENV_ADDRKuldeep Singh
Commit 323d3af59fe4 ("configs: ls1012ardb: Enable CONFIG_SYS_RELOC_GD_ENV_ADDR") enables the config only for LS1012ARDB. Apart from LS1012A-RDB, other platforms such as LS1012A-FRWY, LS2088A and LS1046A-RDB/FRWY also require this config to be enabled. This also helps in resolving booting crash observed in flash environment. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-19configs: ls1012a: Reduce CONFIG_ENV_SIZE to 0x2000Ashish Kumar
All LS1012A board variants have same CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE values. If both config values are same, flash environment cannot be saved. Since, CONFIG_ENV_SECT_SIZE needs to be same as that of flash sector size, this entry cannot be changed. Reduce CONFIG_ENV_SIZE value to 0x2000. This also helps in making config value aligned with other boards environemt size. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Signed-off-by: Ashish Kumar <Ashish.kumar@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-08treewide: mem: Enable MEMTEST via defconfigMichal Simek
There is no reason to enable MEMTEST from headers when was converted to Kconfig already. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04dm: arm64: ls1012a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1012A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-24configs: ls1012afwry: Enable usb network cards supportYinbo Zhu
Enable RTL8152, AX88179 and AX8817X USB network cards support for ls1012afwry Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-06-23Move CONFIG_FSL_ESDHC to defconfigYangbo Lu
Moved CONFIG_FSL_ESDHC from header files to defconfig files. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-06-19configs: Unset CONFIG_SPI_FLASH_BAR, move CONFIG_FSL_QSPI to defconfigAshish Kumar
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19configs: ls1012afrwy: enable sata configs for all ls1012afrwy defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1012afrwy and ls1012afrwy defconfigs that missing one of them or more. Support sata for all ls1012afrwy defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-06armv8: ls1012afrx: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1012a2g5rdb/ls1012afrdm/ls1012afrwy_tfa_defconfig to be loaded by trusted firmware - define BOOTCOMMAND for TFABOOT Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> [YS: remove unnecessary braces] Reviewed-by: York Sun <york.sun@nxp.com>
