path: root/configs/ls1021atsn_qspi_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-25Add support for the NXP LS1021A-TSN boardJianchao Wang
The LS1021A-TSN is a development board built by VVDN/Argonboards in partnership with NXP. It features the LS1021A SoC and the first-generation SJA1105T Ethernet switch for prototyping implementations of a subset of IEEE 802.1 TSN standards. Supported boot media: microSD card (via SPL), QSPI flash. Rev. A of the board uses a Spansion S25FL512S_256K serial flash, which is 64 MB in size and has an erase sector size of 256KB (therefore, flashing the RCW would erase part of U-Boot). Rev. B and C of the board use a Spansion S25FL256S1 serial flash, which is only 32 MB in size but has an erase sector size of 64KB (therefore the RCW image can be flashed without erasing U-Boot). To avoid the problems above, the U-Boot base address has been selected at 0x100000 (the start of the 5th 256KB erase sector), which works for all board revisions. Actually 0x40000 would have been enough, but 0x100000 is common for all Layerscape devices. eTSEC3 is connecting directly to SJA1105 via an RGMII fixed-link, but SJA1105 is currently not supported by uboot. Therefore, eTSEC3 is disabled. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com> Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Jianchao Wang <jianchao.wang@nxp.com> Signed-off-by: Changming Huang <jerry.huang@nxp.com> Signed-off-by: Vladimir Oltean <olteanv@gmail.com> [Vladimir] Code taken from https://github.com/openil/u-boot (which itself is mostly copied from ls1021a-iot) and adapted with the following changes: - Add a008850 errata workaround - Converted eTSEC, MMC to DM to avoid all build warnings - Plugged in distro boot feature, including support for extlinux.conf - Added defconfig for QSPI boot - Added the board/freescale/ls1021atsn/README.rst for initial setup - Increased CONFIG_SYS_MONITOR_LEN so that the SPL malloc pool does not get overwritten during copying of the u-boot.bin payload from MMC to DDR. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
