path: root/configs/ls1021atwr_nor_SECURE_BOOT_defconfig
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-25arm: ls1021atwr: Convert to use driver model TSEC driverBin Meng
Now that we have added driver model support to the TSEC driver, convert ls1021atwr board to use it. This depends on previous DM series for ls1021atwr: http://patchwork.ozlabs.org/patch/561855/ Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Vladimir Oltean <olteanv@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [Vladimir] Made the following changes: - Added 'status = "disabled";' for all Ethernet ports in ls1021a.dtsi - Fixed the confusion between the SGMII/TBI PCS for enet0 and enet1 - a mistake ported over from Linux. Each SGMII PCS lies on the private MDIO bus of the interface (and the RGMII enet2 has no SGMII PCS). - Added CONFIG_DM_ETH to all ls1021atwr_* defconfigs - Completely removed non-DM_ETH support from ls1021atwr - Changed "compatible" string from "fsl,tsec-mdio" to "fsl,etsec2-mdio" and from "fsl,tsec" to "fsl,etsec2" to match Linux
2019-02-19configs: ls1021a: enable sata configs for all ls1021a defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1021a defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls1021a defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-11Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-08-09dm: arm: ls1021a: Move to driver model for USBAlison Wang
This patch enables driver model for USB in defconfigs for LS1021A platforms. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm: ls1021atwr: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-14Convert CONFIG_FSL_DCU_FB to KconfigSanchayan Maity
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB and convert it to Kconfig. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2017-01-18arm: ls1021a: Enable PCIe in defconfigsMinghuan Lian
The patch enables PCIe in ls1021a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18configs: ls1021a: enable DT and DM supportHou Zhiqiang
Enable DT to support Driver Model. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-02armv7: ls1021a: Move SECURE_BOOT option to KconfigYork Sun
Move from CONFIG_SYS_EXTRA_OPTIONS to Kconfig option. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
