path: root/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-26configs: Enable SPL_FSL_PBL for some LayerScape platformsAlison Wang
In commit <db4080d56dec>, SPL_FSL_PBL is removed from the configs of some LayerScape platforms. Actually, SPL_FSL_PBL is needed for SD/NAND boot on LS1021A/LS1043A/LS1046A to create boot binary having SPL binary in PBI format concatenated with u-boot binary. SPL_FRAMEWORK is used on these platforms too. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-25arm: ls1021atwr: Convert to use driver model TSEC driverBin Meng
Now that we have added driver model support to the TSEC driver, convert ls1021atwr board to use it. This depends on previous DM series for ls1021atwr: http://patchwork.ozlabs.org/patch/561855/ Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Vladimir Oltean <olteanv@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [Vladimir] Made the following changes: - Added 'status = "disabled";' for all Ethernet ports in ls1021a.dtsi - Fixed the confusion between the SGMII/TBI PCS for enet0 and enet1 - a mistake ported over from Linux. Each SGMII PCS lies on the private MDIO bus of the interface (and the RGMII enet2 has no SGMII PCS). - Added CONFIG_DM_ETH to all ls1021atwr_* defconfigs - Completely removed non-DM_ETH support from ls1021atwr - Changed "compatible" string from "fsl,tsec-mdio" to "fsl,etsec2-mdio" and from "fsl,tsec" to "fsl,etsec2" to match Linux
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-11Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-08-09dm: arm: ls1021a: Move to driver model for USBAlison Wang
This patch enables driver model for USB in defconfigs for LS1021A platforms. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm: ls1021atwr: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-14Convert CONFIG_FSL_DCU_FB to KconfigSanchayan Maity
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB and convert it to Kconfig. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2017-01-18arm: ls1021a: Enable PCIe in defconfigsMinghuan Lian
The patch enables PCIe in ls1021a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
