path: root/configs/ls1021atwr_sdcard_qspi_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-06configs: Resync with savedefconfigTom Rini
2020-02-04dm: arm: ls1021a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1021A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-26configs: Enable SPL_FSL_PBL for some LayerScape platformsAlison Wang
In commit <db4080d56dec>, SPL_FSL_PBL is removed from the configs of some LayerScape platforms. Actually, SPL_FSL_PBL is needed for SD/NAND boot on LS1021A/LS1043A/LS1046A to create boot binary having SPL binary in PBI format concatenated with u-boot binary. SPL_FRAMEWORK is used on these platforms too. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-25arm: ls1021atwr: Convert to use driver model TSEC driverBin Meng
Now that we have added driver model support to the TSEC driver, convert ls1021atwr board to use it. This depends on previous DM series for ls1021atwr: http://patchwork.ozlabs.org/patch/561855/ Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Vladimir Oltean <olteanv@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [Vladimir] Made the following changes: - Added 'status = "disabled";' for all Ethernet ports in ls1021a.dtsi - Fixed the confusion between the SGMII/TBI PCS for enet0 and enet1 - a mistake ported over from Linux. Each SGMII PCS lies on the private MDIO bus of the interface (and the RGMII enet2 has no SGMII PCS). - Added CONFIG_DM_ETH to all ls1021atwr_* defconfigs - Completely removed non-DM_ETH support from ls1021atwr - Changed "compatible" string from "fsl,tsec-mdio" to "fsl,etsec2-mdio" and from "fsl,tsec" to "fsl,etsec2" to match Linux
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-02-19configs: ls1021a: enable sata configs for all ls1021a defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1021a defconfigs that missing one of them or more. enable CONFIG_DM_MMC for some defconfigs to support CONFIG_BLK Support sata for all ls1021a defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-11Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-08-09dm: arm: ls1021a: Move to driver model for USBAlison Wang
This patch enables driver model for USB in defconfigs for LS1021A platforms. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm: ls1021atwr: Add distro boot supportAlison Wang
This patch includes common config_distro_defaults.h and config_distro_bootcmd.h for u-boot enviroments to support distro boot which automatically scan boot.scr from storage devices(e.g. SD/USB/SATA/SCSI disk) and execute autoboot script on LS1021ATWR board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-14Convert CONFIG_FSL_DCU_FB to KconfigSanchayan Maity
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB and convert it to Kconfig. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
