path: root/configs/ls1028ardb_tfa_defconfig
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-08treewide: mem: Enable MEMTEST via defconfigMichal Simek
There is no reason to enable MEMTEST from headers when was converted to Kconfig already. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-05-08configs: Resync with savedefconfigTom Rini
2020-04-30Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb, ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb. - Add GICv3 support for ls1028a, ls2088a, ls1088a. - Add lpuart support on ls1028aqds. - Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based platforms.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28configs: ls1028a: Enable GIC_V3_ITS configHou Zhiqiang
Enable GIC_V3_ITS config to initialize the GIC redistributor tables. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Wasim Khan <wasim.khan@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-03-30configs: disable eMMC HS200 support on layerscape platformsYangbo Lu
The eMMC HS200 speed mode on Layerscape platforms has not been supported properly. The eSDHC clock tuning has not been implemented by now. So disable it until it is supported properly in case of any potential issues. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-02-04configs: ls1028a: Enable FSPI supportKuldeep Singh
Enable FSPI controller support. So, flash environment can now be used Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-16configs: ls1028a: use default SDHC clock divider valueYangbo Lu
The SDHC clock divider value for LS1028A should be default 2, not 1. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
2019-12-26configs: ls1028ardb: enable ugreen usb network card AX88179 and AX8817X drvierYinbo Zhu
enable ls1028ardb ugreen usb network card AX88179 and AX8817X driver Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-26configs: ls1028ardb: enable usb net r8152_ethYinbo Zhu
Enable ls1028ardb usb net r8152_eth Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-26configs: ls1028a: Enable FSPI_AHB_EN_4B configKuldeep Singh
Enable 4-byte Fast Read command for Flexspi AHB mode Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-29configs: ls1028a: enable CMD_DMAlex Marginean
Since at least some of the drivers relevant to LS1028A are now following DM, it's useful to have dm command enabled by default. Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-27configs: ls1028a: enable OF_LIBFDT_OVERLAYAlex Marginean
LS1028A QDS board supports multiple combinations of SerDes protocols and multiple add-on cards with Ethernet PHYs. Some of them require specific configuration in Linux DT, and the plan is to use DT overlays for them. Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-09-12configs/ls1012ardb,lx2160ardb,ls1028ardb: add esdhc hs200 configYinbo Zhu
Enable CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK and CONFIG_MMC_HS200_SUPPORT config for ls1012ardb, ls1012ardb, lx2160ardb in defconfig file Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-08-22configs: ls1028a: Enable DM support for pcf2127 rtcChuanhua Han
Enable related configs on all ls1028aqds boards to support pcf2127 rtc DM function. Signed-off-by: Chuanhua Han <chuanhua.han@nxp.com> Reviewed-by: Alex Marginean <alexm.osslist@gmail.com> Tested-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-07-25configs: ls1028a: enable networking options in rdb, qds defconfigAlex Marginean
Enables ethernet, MDIO, PHY drivers for LS1028A RDB and QDS. Signed-off-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-06-23Move CONFIG_FSL_ESDHC to defconfigYangbo Lu
Moved CONFIG_FSL_ESDHC from header files to defconfig files. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-06-19arm: ls1028a: define the integrated PCI bus (ECAM)Alex Marginean
LS1028A includes an integrated PCI bus with 11 PCI functions residing on bus 0. ECAM plus the device register space takes up 256MB of address space. Signed-off-by: Alex Marginean <alexm.osslist@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22config: enable SP805 watchdog support for LS1028AQiang Zhao
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22armv8: ls1028ardb: Add support for LS1028ARDBYuantian Tang
LS1028A is an ARMv8 implementation. LS1028ARDB is an evaluation platform that supports the LS1028A family SoCs. This patch add basic support of the platform. Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com> Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
