path: root/configs/ls1043aqds_nand_defconfig
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-03-03board: ls1043a: enable EFI_LOADER_BOUNCE_BUFFERMian Yousaf Kaukab
EFI applications need bounce buffers to work properly on these platforms. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19configs: ls1043aqds: enable sata configs for all ls1043aqds defconfigsPeng Ma
Add CONFIG_AHCI CONFIG_SATA_CEVA CONFIG_DM_SCSI for some ls1043aqds defconfigs that missing one of them or more. Support sata for all ls1043aqds defconfigs Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-24armv8: ls1043aqds: enable FSL PPAHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18armv8: ls1043a: Enable PCIe and E1000 in defconfigsMinghuan Lian
The patch enables PCIe and E1000 in ls1043a defconfigs and removes unused PCIe related macro defines. Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03cmd: move CMD_PXE to KconfigYann E. MORIN
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs. However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device. However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable. But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS. Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Joe Hershberger <joe.hershberger@ni.com> [trini: Make it select MENU, run moveconfig.py] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-06armv8: fsl-layerscape: Move DDR config options to KconfigYork Sun
Move DDR3, DDR4 and realted options to Kconfig and clean up existing uses. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06armv8: ls1043: Enable CONFIG_DM_USB in defconfigsSriram Dash
Enables driver model flag CONFIG_DM_USB for LS1043A platform defconfigs. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
