path: root/configs/ls1046ardb_qspi_defconfig
2020-05-19configs: ls1046a: Define ENV_ADDR valueKuldeep Singh
CONFIG_ENV_ADDR helps in picking environment from flash before DDR init. The macro value is already defined in ls1046ardb_tfa_defconfig, also define the value as 0x40300000 in qspi_defconfig. ls1046aqds has one spansion flash "S25FL128S_64K" of size 16M with sector size 64K. Correct ENV_ADDR and ENV_SECT_SIZE value for QSPI and TFA defconfigs of the board. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-19configs: ls1046a: Move SPI_FLASH_SPANSION to defconfigKuldeep Singh
Enable CONFIG_SPI_FLASH_SPANSION in defconfigs of LS1046ARDB and LS1046AQDS which have two spansion flases i.e s25fs512s each of size 64M. Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-30Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriqTom Rini
- Add DM_ETH support for DPAA1, DPAA2 based RDB platforms: ls1046ardb, ls1043ardb, lx2160ardb, ls2088ardb, ls1088ardb. - Add GICv3 support for ls1028a, ls2088a, ls1088a. - Add lpuart support on ls1028aqds. - Few bug fixes and updates on ls2088a, ls1012a, ls1046a, ls1021a based platforms.
2020-04-29configs: enable DM_ETH support for LS1046ARDBMadalin Bucur
Enable DM_ETH on all the defconfigs for the LS1046ARDB board. Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-03-30dm: arm64: ls1046a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1046A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-22configs: Unset CONFIG_SPI_BAR for all LS1046A defconfigsRajat Srivastava
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-22configs: ls1046: Update mtd-id for QSPI nor in mtdparts variableKuldeep Singh
Update mtd-id for QSPI nor due to change introduced in mtd/spi in linux 5.0. commit 84d043185dbe ("spi: Add a driver for the Freescale/NXP QuadSPI controller") This modification is only for linux kernel version >= 5.0. To use bootargs for kernel < 5.0, use the following bootargs CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:2m(uboot),14m(free)" CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:2m(uboot),14m(free)" Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-03board: ls1046a: enable EFI_LOADER_BOUNCE_BUFFERMian Yousaf Kaukab
EFI applications need bounce buffers to work properly on these platforms. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-12-06arm64: ls1046ardb: enable DM support for sataPeng Ma
Enable related configs to support sata DM feature. Signed-off-by: Peng Ma <peng.ma@nxp.com> [YS: moveconfig.py -s -d] Reviewed-by: York Sun <york.sun@nxp.com>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-26configs: Disable 4k erase sector size for spansion "s25fs512s" flashAshish Kumar
4K erase size is used only in case of hydrid mode which is not supported on any NXP platform with flash "s25fs512s". Supported mode is uniform sector, with erase size 256kiB. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-02Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/configs/ls1046aqds.h include/configs/ls1046ardb.h
2017-08-01arm64: ls1046ardb: Add distro boot supportQianyu Gong
Tested on ls1046ardb with automatically boot Ubuntu from SD card or USB disk, if it fails to detect external storage disk, fall back to qspi boot. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01armv8: ls1046a: move CONFIG_CMD_USB to defconfigQianyu Gong
Move the macro to defconfig to take effect globally. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-02-03Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/ls1046aqds_defconfig configs/ls1046aqds_nand_defconfig configs/ls1046aqds_qspi_defconfig configs/ls1046aqds_sdcard_ifc_defconfig configs/ls1046aqds_sdcard_qspi_defconfig configs/ls1046ardb_emmc_defconfig configs/ls1046ardb_qspi_defconfig configs/ls1046ardb_sdcard_defconfig
2017-01-27armv8: ls1046a: enable usb in defconfigTang Yuantian
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
