path: root/configs/mvebu_db_armada8k_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-11-07configs: Resync with savedefconfigTom Rini
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-21arm64: mvebu: defconfig: enable CONFIG_CMD_NVMEHeinrich Schuchardt
An NVME drive may be installed on the MACCHIATObin board using the PCIe slot or on the Clearfog Pro using mini a PCI-e slot. With the configuration change it becomes usable. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-11-30arm: mvebu: configs: armada8k: use 2 DRAM banksBaruch Siach
Commit 2b4d964718c0 ("arm64: mvebu: a8k: autodetect RAM size") added an ATF query to get the detected RAM size on Armada 8K platforms. To be usable we must have 2 DRAM banks. Set Armada 8K configurations to 2 banks. Cc: Konstantin Porotchkin <kostap@marvell.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-07-09configs: Resync with savedefconfigTom Rini
2018-05-29arm64: mvebu: defconfig: enable CONFIG_AHCI_MVEBUKen Ma
This patch enables the new ahci mvebu driver for marvell arm64 platform SOCs(A3k and A8k). And since AHCI_MVEBU selects SCSI_AHCI, so "CONFIG_SCSI_AHCI=y" is removed from those default config files. Signed-off-by: Ken Ma <make@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13spi: Migrate CONFIG_KIRKWOOD_SPI to KconfigTuomas Tynkkynen
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-11-16arm: mvebu: configs: Enable DISTRO_DEFAULTS for MACCHIATObinHeinrich Schuchardt
Enable DISTRO_DEFAULTS for mvebu_db_armada8k_defconfig mvebu_mcbin-88f8040_defconfig Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-12arm64: mvebu: use single defconfig for Armada8K development boardsIgal Liberman
Currently, Marvell Armada8k development board use 3 different defconfigs: mvebu_db-88f7040-nand_defconfig mvebu_db-88f7040_defconfig mvebu_db-88f8040_defconfig Having 3 different defconfigs makes maintenance difficult. This patch removes the defconfigs mentioned above and introduce a new defconfig which represents the Armada8k family. NOTE: In order not to break automatic tools compilation, a default device-tree is set in the defconfig (armada-8040-db). However, when compiling u-boot, the user MUST explicitly export the DEVICE_TREE for the requested board because using A80x0 device-tree on A70x0 might break the device. For more information, refer to "doc/README.marvell" (intoduced in this patch). Change-Id: I98515b6306498358f3722ecf7ac4c87f236ebbd8 Signed-off-by: Igal Liberman <igall@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
