path: root/configs/mx53loco_defconfig
2020-04-28configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25Convert CONFIG_USB_EHCI_MX5 to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_USB_EHCI_MX5 Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13imx: move CONFIG_VIDEO_IPUV3 to defconfigsAnatolij Gustschin
2017-12-29imx: Unify CONFIG_BOOTDELAYFabio Estevam
In order to provide a consistent user experience for imx board users, remove the custom CONFIG_BOOTDELAY values from defconfig files, so that all boards can use the default two second delay. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-12-12ata: Migrate CONFIG_DWC_AHSATA to KconfigTuomas Tynkkynen
2017-10-30configs: Resync with savedefconfigTom Rini
2017-10-12mx53loco: Let CONFIG_DISPLAY_CPUINFO be selectedFabio Estevam
With CONFIG_DISPLAY_CPUINFO=y we get a "Reset cause" line, which brings important information of the reboot cause. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30arm: Re-sync ARCH_MX5 / MX51 / MX53 CONFIG optionsTom Rini
A few boards had not been fully re-synced with CONFIG_ARCH_MX5 / CONFIG_MX51 / CONFIG_MX53 being in Kconfig. Do so now. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
