path: root/configs/nas220_defconfig
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2015-01-14Add support for Seagate BlackArmor NAS220Evgeni Dobrev
Add support for Seagate BlackArmor NAS220 Signed-off-by: Evgeni Dobrev <evgeni@studio-punkt.com>
