path: root/configs/orangepi_lite2_defconfig
2020-03-18sunxi: Remove no longer needed default options from defconfigsAndre Przywara
Now that those common Allwinner config symbols are defined automatically for all boards in their Kconfig files, we can remove the now redundant definitions from the boards' _defconfig files. Some boards had a differing definiton for some of those symbols, it looks like mostly to "merge races" when the symbol was introduced (new board *_defconfig file missed the "add symbol to all files" patch). Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <mripard@kernel.org> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-16sunxi: H6: Enable USB for existing boardsAndre Przywara
So far USB was not enabled for the Allwinner H6 boards, as the PHY driver was not ready and the clock gates were missing. Since this is now fixed, let's add the PHY and the OHCI/EHCI drivers to the build, for all existing H6 boards. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Tested-by: Corentin Labbe <clabbe.montjoie@gmail.com> # Pine-H64 Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-07-16sunxi: H6: move LPDDR3 timing definition into separate fileAndre Przywara
Currently the H6 DRAM driver only supports one kind of LPDDR3 DRAM. Split the timing parameters for this LPDDR3 configuration into a separate file, to allow selecting an alternative later at compile time (as the sunxi-dw driver does). Signed-off-by: Andre Przywara <andre.przywara@arm.com> Tested-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-07-15sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to KconfigAndre Przywara
The choice of the SPL_TEXT_BASE is not really a decision that should be specified by each board's defconfig, as this setting is actually dictated by the SoC's memory map and the BootROM behaviour. To make this obvious and reduce the clutter in the defconfig files, let's specify the SoC constraints in the Kconfig stanza. This allows us to remove these lines from the defconfig files again. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-13board: allwinner: sun50i-h6: Add Orangepi Lite2 supportJagan Teki
OrangePi Lite2 is Allwinner H6 based open-source SBC, which support: - Allwinner H6 Quad-core 64-bit ARM Cortex-A53 - GPU Mali-T720 - 1GB LPDDR3 RAM - AXP805 PMIC - AP6356S Wifi/BT - USB 2.0, USB 3.0 Host, OTG - HDMI port - 5V/2A DC power supply Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
