path: root/configs/poplar_defconfig
2019-07-01poplar: increase SYS_MALLOC_F_LEN for DM_FLAG_PRE_RELOC supportShawn Guo
There is a regression seen on Poplar platform, which doesn't even show a U-Boot version banner on booting. It turns out that due to landing of commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver"), we need to increase SYS_MALLOC_F_LEN from its default size 0x400, as pre-relocation requires more memory there. Let's increase SYS_MALLOC_F_LEN to 0x4000 to fix the regression. Thanks to Andreas Färber <afaerber@suse.de> for reporting, and Bin Meng <bmeng.cn@gmail.com> for trouble shooting. Reported-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Andreas Färber <afaerber@suse.de>
2019-04-23poplar: enable Ethernet driver supportShawn Guo
The 'phy' reset of gmac device in kernel device tree is not generic enough for u-boot to use, so we need to overwrite the 'resets' property as needed. With this device tree fixup and poplar_defconfig changes, Ethernet starts working on Poplar board. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-15mmc: Convert HI6220 MMC driver to driver modelManivannan Sadhasivam
Convert HiSilicon HI6220 MMC driver based on DWMMC IP to driver model. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Enable this on poplar] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-14poplar_defconfig: enable fastboot supportShawn Guo
It enables fastboot support on Poplar board by using DWC2 OTG gadget driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-22ARM: poplar: Use Kconfig to enable CONFIG_FAT_WRITETuomas Tynkkynen
The symbol's been converted to Kconfig for a while, poplar is the only one #defining it. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-10ARM64: poplar: hi3798cv200: u-boot support for Poplar 96BoardsJorge Ramirez-Ortiz
This port adds support for: 1) Serial 2) eMMC 3) USB It has been tested with ARM TRUSTED FIRMWARE running u-boot as the BL33 executable [see board's README] eMMC has been tested for reading and booting the loader and linux kernels as well as saving the u-boot environment. USB has been tested with ASIX networking adapter and SanDisk 7.4GB drive. PSCI has been tested via the reset call (PSCI executes from DDR) The firwmare upgrade process has been tested via TFTP and USB FAT filesystem containing the fastboot.bin image in one of the partitions. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
