path: root/configs/qemu_mips64el_defconfig
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-01MIPS: kconfig: merge targets qemu_mips and qemu_mips64Daniel Schwierzeck
Now the user can separately select the CPU type. Thus the targets qemu_mips and qemu_mips64 can be merged to a single target. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
