path: root/configs/seaboard_defconfig
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: mmc: Enable DM_MMC_OPS by default with DM_MMCSimon Glass
These two options go together and it is best to do the conversion in one step. So enable DM_MMC_OPS by default if DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-27ARM: tegra: fix ULPI PHY on Ventana and SeaboardStephen Warren
Commit ce02a71c2374 "tegra: dts: Sync tegra20 device tree files with Linux" enabled the ULPI USB port on Ventana, but made no attempt to ensure that U-Boot code could handle this. In practice, various code is missing, and various configuration options are not enabled, which causes U-Boot to hang when attempting to initialize this USB port. This patch enables ULPI PHY support on Ventana, and adds the required pinmux setup for the port to operate. Note that Ventana is so similar to Seaboard that this change is made in the Seaboard board file, which is shared with Ventana. Seaboard also has the ULPI USB port wired up in hardware, although to an internal port that often doesn't have anything attached to it. However, the DT nodes for the USB controller and PHY had different status property values, so the port was not initialized by U-Boot. Fix this inconsistency, and enable the ULPI port, just like in the Linux kernel DT. This likewise requires enabling ULPI support in the Seaboard defconfig. Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-07-05video: tegra: Move to using simple-panel and pwm-backlightSimon Glass
We have standard drivers for panels and backlights which can do most of the work for us. Move the tegra20 LCD driver over to use those instead of custom code. This patch includes device tree changes for the nvidia boards. I have only been able to test seaboard. If this patch is applied, these boards will also need to be synced with the kernel, and updated to use display-timings: - colibri - medcom-wide - paz00 - tec Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-16tegra: Convert CONFIG_PWM_TEGRA to KconfigSimon Glass
Move this option to Kconfig and clean up the header files. Adjust the only user (the LCD driver) to work with the new driver. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Convert tegra20 LCD driver to driver modelSimon Glass
Move this driver over to use driver model. This involves rearranging the code somewhat. The effect is that everything is run from the probe() method. Boards which use this are fixed up, but only seaboard is tested. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Rename CONFIG_VIDEO_TEGRA to CONFIG_VIDEO_TEGRA20Simon Glass
This option refers only to the tegra20 video driver, so name it as such to avoid confusion with tegra124. Also move this option to Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
