path: root/configs/sksimx6_defconfig
2020-07-06configs: Resync with savedefconfigTom Rini
2020-04-28configs: Resync with savedefconfigTom Rini
2020-02-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD_DEVICE -> CONFIG_MTDMiquel Raynal
Like in Linux, just use CONFIG_MTD to compile the MTD stack. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-08imx: sksimx6_defconfig: remove SPL misc option to fix build errorAnatolij Gustschin
Remove CONFIG_SPL_DRIVERS_MISC_SUPPORT since it is already defined in include/configs/mx6_common.h for SPL builds. When this option is in defconfig, we get build warnings (or errors when building with -Werror). Signed-off-by: Anatolij Gustschin <agust@denx.de>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-23Convert CONFIG_FSL_USDHC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_FSL_USDHC Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Add IMX8M, TARGET_S32V234EVB to FSL_USDHC list] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2018-01-12mx6: Support SKS-Kinkel sksimx6 BoardStefano Babic
Board has 1GB RAM and boots from SD Card U-Boot SPL 2018.01-rc3-00005-ga1898b8 (Jan 02 2018 - 13:48:54) BT_FUSE_SEL already fused, will do nothing Trying to boot from MMC1 U-Boot 2018.01-rc3-00005-ga1898b8 (Jan 02 2018 - 13:48:54 +0100) CPU: Freescale i.MX6DL rev1.2 996 MHz (running at 792 MHz) CPU: Commercial temperature grade (0C to 95C) at 40C Reset cause: POR I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME] Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
