path: root/configs/smdk5250_defconfig
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-25arm: exynos: realign the code to allow support for newer 64-bit platformsThomas Abraham
The existing Exynos 32-bit platform support needs to be realigned in order to support newer 64-bit Exynos platforms. The driver model will be utlized for drivers on the 64-bit Exynos platforms and so some of the older platform support code would not be required for the newer 64-bit Exynos platforms. Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_WM8994 to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_MAX98095 to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_I2S_SAMSUNG to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_I2S to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_CMD_SOUND to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_SOUND to KconfigSimon Glass
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
