path: root/configs/snapper9g20_defconfig
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2017-08-11Convert CONFIG_CMD_PCA953X to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_PCA953X Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2015-04-18ARM: snapper9260: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-28malloc_f: remove redundant defalut values of CONFIG_SYS_MALLOC_F_LENMasahiro Yamada
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig as 0x400. Each defconfig or Kconfig need not repeat the same value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: at91: snapper: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
