Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
- Assorted fixes
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
The default mtdparts value grew a trailing zero during the Kconfig
conversion. This is because the mtdparts value in the header file
had a \0 at the end, which got misconverted into plain 0 instead of
being dropped.
Fixes: 43ede0bca7fc ("Kconfig: Migrate MTDIDS_DEFAULT / MTDPARTS_DEFAULT")
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Most boards currently use SPI_FLASH_MTD only in U-Boot proper, not in
SPL. They often rely on hacks in the board header files to include
this option conditionally. To be able to fix this, we previously
introduced a separate option SPL_SPI_FLASH_MTD.
Therefore we can now adjust the Makefile and change the code in
sf_probe.c and sf_internal.h to use CONFIG_IS_ENABLED(SPI_FLASH_MTD).
We also need to move all occurences of CONFIG_SPI_FLASH_MTD from the
header files to the according defconfigs. The affected boards are
socfpga, aristainetos, cm_fx6, display5, ventana, rcar-gen2, dh_imx6
and da850evm.
We do this all in one patch to guarantee bisectibility.
This change was tested with buildman to make sure it does not
introduce any regressions by comparing the resulting binary sizes.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Acked-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
These boards don't have a watchdog enabled in SPL, so make sure
CONFIG_SPL_WDT is not enabled.
Fixes: commit 6874cb72204f ("watchdog: Split WDT from SPL_WDT")
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
CONFIG_SYS_SPI_U_BOOT_OFFS
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
[trini: Expose this for SPL_SPI_SUNXI for now]
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
[trini: Re-run migration]
This commit moves common config options used in all socfpga boards
to select/imply in Kconfig. This both cleans up the defconfig files
as well as makes future changes easier.
Options implied/defaulted for all sub-arches:
- SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS
Options implied/defaulted for implied for A10 & gen5:
- FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE
Options implied/defaulted for gen5:
- SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR
Now that new SPI NOR layer uses stateless 4 byte opcodes by default,
don't enable SPI_FLASH_BAR. For SPI controllers that cannot support
4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c,
renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to
not break functionality.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Stefan Roese <sr@denx.de>
Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
None of the SoCFPGA platforms will support EFI/ISO partition types that
is needed for DISTRO_DEFAULTS. SoCFPGA bootroom will only support 0xa2
partition type.
This is needed to help limit the size of the SPL to within the 64k limit
that is required for SoCFPGA.
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
Add the DM reset driver to socfpga defconfigs.
Enable DM I2C driver on SoCFPGA platforms.
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all
configurations using it to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
A number of platforms include config_distro_defaults.h but do not enable
CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and
re-sync config files.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Currently, socfpga_common.h does not allow configurations without
network support. This is because CONFIG_CMD_PXE is defined in this
file and distro mode has DHCP hard-coded as available.
Fix this by moving CONFIG_CMD_PXE and CONFIG_MENU to the defconfigs
and by making DHCP optional in BOOT_TARGET_DEVICES(func).
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
Enable CONFIG_CMD_PART item, as default environment requires it
and complains this command in unknown.
Signed-off-by: Andrey Zhizhikin <andrey.z@gmail.com>
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_FPGA_SOCFPGA
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
This change migrates the USB_DWC2 configuration item to Kconfig
and runs moveconfig to adjust header files and defconfig.
Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com>
Split off into a separate patch:
Ran moveconfig to migrate other boards:
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
This removes the default environment from the A5 socdk headers
and instead uses the common environment provided in
socfpga_common.h which now uses distro boot.
Add support to boot from the custom a2 type partition.
Change default devicetree name to match devicetree name in
upstream kernel source.
Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
Changes in v3:
- Fix small typo in defconfig, missing "C"
Changes in v2:
- Remove unneeded CONFIG_BOOTFILE
- Fix dtb name
a5config test
This commit was created as follows:
[1] Rename the option with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_CONSOLE_ENV_OVERWRITE
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
