path: root/configs/stm32h743-eval_defconfig
2020-06-04Convert CONFIG_BOARD_LATE_INIT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_LATE_INIT Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-15rename symbol: CONFIG_STM32 -> CONFIG_ARCH_STM32Trevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2019-11-21configs: Resync with savedefconfigTom Rini
2019-10-22configs: stm32h743-eval: Disable CONFIG_NET flagPatrice Chotard
Network support was never added on this board, disable CONFIG_NET flag to avoid following warning: ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ==================================================== Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-01-15configs: stm32: Remove CONFIG_OF_EMBEDPatrice Chotard
Building with CONFIG_OF_EMBED generates build warnings, as it should only be used for debugging purposes. Remove CONFIG_OF_EMBED from all stm32 config files which are using this flag. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32h743-evaluation: Add DISTRO_DEFAULT supportPatrice Chotard
Add DISTRO_DEFAULT support to be able to boot on mmc by default on boot. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32h7xx: Migrate CONFIG_CMD_CACHE to defconfigPatrice Chotard
Remove CONFIG_CMD_CACHE from include/configs/stm32h7xx.h and enable it in stm32h7xx_defconfig Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2017-10-08configs: stm32h743-eval: enable filesystem related flagsPatrice Chotard
Enable CMD_GPT/EXT2/EXT4/EXT4_WRITE/FAT_FS_GENERIC flags Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-08configs: stm32h743-eval: enable SDMMC supportPatrice Chotard
Enable CMD_MMC, DM_MMC and STM32_SDMMC2 flags Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-09-22board: Add stm32h7 SoC, discovery and evaluation boards supportPatrice Chotard
This patch adds support for stm32h7 soc family, stm32h743 discovery and evaluation boards. For more information about STM32H7 series, please visit: http://www.st.com/en/microcontrollers/stm32h7-series.html Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
